How many qts on a tranny pan pull & converter drain - Ford Powerstroke Diesel Forum
Old 01-14-2011, 11:04 PM
I just installed a new converter this week and now want to replace the tc solenoid in the morning b/c I still have a lock up problem.
Anyway, I am pulling the pan and will drain the converter. I bought 13 qts of Mercon V and the deep filter. Am I right on both????????????????????
My luck these days I will need the shallow filter and 15 qts of Dex III
Later Skater
Old 01-15-2011, 01:31 PM
I could be wrong, but I thought the trans used 17qts?
Old 01-15-2011, 09:34 PM
Yea, I just did 13 and still not on the stick, I replaced the tc soleniod block on the valve body, So I think I got all the fluid out.
Old 01-15-2011, 09:39 PM
yah im pretty sure its 15qts....
Old 01-15-2011, 09:55 PM
fill it till its on the stick. duh!
Old 01-15-2011, 11:56 PM
I would put 10 in it. while youre foot is on the break slowly shift thru the gears stopping for a bit at each one. Do this from park all the way to 1 and than from 1 all the way to park. you should start to feel the change. Than check level and add.
