have a 99 f350 mbrp 5" exhaust, sct livewire, afe cold air, 4" lift, 35's... Went to go to work this morning started truck n ran fine for 15 minutes started cruising down the road and truck sputtered a bunch and died... realized that its popping the number 30 fuse under dash + only does it when cold outside... on warmer days have no problem.. any help would be great!!
cant remember which fuse
look inside your fuel bowl, remove the filter and check and see if your fuel heater element has fallen to the bottom of the bowl, that is, touching. (it always is in the bottom), but i don't remember which fuse, but this sounds like the problem i had.
if it is this, it shorts it out, around $60 at ford i believe for the part, which once you see it, it's laughable |
PS: THE WARM OUTSIDE THING, I'M NOT SURE. JUST REMEMBER MINE DID THIS LIKE 3 YEARS AGO, AND IT WAS THE FUEL HEATER ELEMENT INSIDE THE BOWL. EASY TO REPLACE AND FIX.
You don't have to "fix" it, just unplug it and drive (worry about the repair at some later date....)
awsome ill try that out n see what i find... if the element itself is touching the bottom means its shorting out? also would this have nething to do with the problem im having only when wet out... the truck spits and sputterz only when its wet/raining... and which plug do u i pull for the heater?
Do a Search and read-up on some of them ![]() Here's the connector at the bottom. |
awsome thanks for the help that def was the problem... ill have to look into that windshield wiper interferance
