!0K mod with no tunes or gauges? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-13-2011, 09:24 AM Thread Starter
Fireman40's Avatar
I want to do the 10K mod. I do not have any gauges or tunes. Will this hurt my truck. I saw someone post at one time about now going below a 6k without having exhaust temp gauges.
2012 F-250 Crew Cab LB 4x4 OFF ROAD
BONE STOCK
Fireman40 is offline
post #2 of 6 Old 01-13-2011, 02:14 PM
i have a full set of gauges, and with a 10k mod, i barely noticed any changes, or at least nothing to get at ALL worried about.
and dont go below 10k if you like your motor. they run like crap and lope really nasty, if you have to do any "real" cold starts with your truck, you will serisouly regret it.
Ski-dooin it is offline
post #3 of 6 Old 01-13-2011, 05:30 PM
codysweat's Avatar
i dont reccomend it. get a fpr for like 30 bucks or shim it with a bb better than messing with the icp...
1/30/98 EARLY 99 7.3 F350 DRW CC 4X4 4R100 3.73 LARIAT
codysweat is offline
post #4 of 6 Old 01-13-2011, 05:38 PM Thread Starter
Fireman40's Avatar
I stuck it in there today just to see how it is. The only thing good about it was it made a kinda cool sound in the ehaust and maybe had a little more snap on the throttle. Other than that it has a nasty idle. If i pulled up next to someone of the high way with a truck sounding like mine I would think it was broke. The only reason I would consider keeping it is for a better fuel mileage. If it does that. What exactly is the mod supposed to do.
BONE STOCK
post #5 of 6 Old 01-14-2011, 12:40 AM
hvprohop23's Avatar
Not tryin to steal the thread but what is the 10K mod? i hear alot about it but have yet to actually find out what it is?
Ford F250 Ext Cab Short Bed 7.3L PowerStroke
S&B Cold Air Intake
ATS Ported Shroud Housing
Straight Pipe
Waste Gate Unplugged
Glowshift Gauges Boost, Trans, EGT
*DP Tuner coming soon*
And YES this is the sh*tiest looking hay you'll ever see
hvprohop23 is offline
post #6 of 6 Old 01-14-2011, 04:44 AM Thread Starter
Fireman40's Avatar
basically you take a 10K resistor and plug it into the the red/grey and green/blue wire on your pcm plug. These are your sending and recieving wires and if you put a resitor connecting the 2 it addes resistance wich tricks your pcm into giving more fuel. I dont see any advantages of it. Just a nasty truck shaking idle.
BONE STOCK
