so my clutch slip today - Ford Powerstroke Diesel Forum
Old 07-02-2007, 07:59 PM
going uphill around 16 hundred rpm, around 40 something, gave gas, rpm went up, let off, rpm drop off...
clutch slips now...
so, what clutch should i get? the luk one seems to be the choice around here, but i dont like the idea of having to remove springs and put springs on just so i have a feel of a pedal... which clutch kit offers a close to stock feel?
need flywheel too...
or should i just let ford do it?
Old 07-02-2007, 08:00 PM
my southbend fells a tad lighter then stock with the spring pulled out.. I cant make it slip i tried.. it just rips the tires appart
Old 07-02-2007, 09:07 PM
Send a message via AIM to jngreen
I know the Luk comes with a flywheel, Pretty sure the Southbend does too. Luk is a good clutch at a good price.
South Bend has a reputation of being one of the best clutch builders out there so you pay more for the name.
Either way you will be happy.
Old 07-02-2007, 09:22 PM
Southbend sells ya everything. you get clutch, flywheel, pressure plate, throw out bearing, crank bolts and pressure plate bolts, pilot bearing .. and they have the updated fork too if you have the bad one.. it is definatly not cheap but I'm confident I wont have to replace it again.. and since it takes so little effort to push the clutch in the hydraulics/slave should be a little happier
Old 07-02-2007, 10:21 PM
cj ford, could ya show me some pictures of your setup and stuff?
Old 07-02-2007, 11:04 PM
heres the link to it when I got it delivered to me
I'm so happy
Old 07-03-2007, 06:23 AM
South Bend Clutch all the way.
Old 07-03-2007, 07:41 AM
Thats Mr. Oil Leak.....
Southbend! only way to go!
Old 07-14-2007, 05:45 PM
ok, so who do i give money to now?
someone want to help me spend my money?
can the southbend be used with the stock helper spring still in there? what is this issue with the pedal being stuck to the ground i hear? how do you guys replace that spring?
what is the avg price for an install? where do i go to?
Old 07-14-2007, 06:21 PM
use a screw driver to pop off the spring on the pedal its a 2 second job.. then it will feel pretty much like a stock pedal.. I installed mine it took 4 hrs start to finish... I dont know where to send ya to have it installed.. Some of our vendors sell them here.. I just went right to southbend and ordered mine over the phone .. I delt with Peter
