1st issue with my "new" old F350
after about a month of owning my truck, i have run into my first issue. i've owned fords before, so unusual electrical issues dont come as a shock. not sure about this one tho...
on sunday afternoon while the game was on, i kept hearing someone laying on the horn out in front of the house. we live in the sticks, we've had runaway cows blocking the road recently, i thought nothing of it at first. it kept happening, i went out and didnt see a thing. it happened again a bit later, and i got outside to find that it was my truck sitting in the driveway, horn blaring! i opened the door and it stopped. i closed the door, stayed off until dome lite went out, then it layed on the horn again. no lights blinking like an alarm going off, and it isnt short repeated blasts of the horn, its just a steady blast. open the door: off, light goes out: on. anyway, i dont have the cash to take it to the auto electric shop right now with christmas coming. i just pulled the fuse for the horn. my question is, am i allowing some potentially damaging problem to continue that i'm not seeing cause the horn blast was the symptom, and i temporarily cured that? anybody have any idea what might be going on? it has been freezing cold, and ive noticed that when its cold the radio volume dial turns the volume up either way you turn it. that stops when the truck warms up. is this an issue like that maybe? i cant have the horn blasting all the time, but i could disconnect the battery and leave it sit til i fix it. i havent sold the old truck that i'm replacing yet, so i could just drive that. any thoughts would be appreciated. |
Has it rained lately? The GEM could be getting wet and causing weird issues.
it hasnt rained, but it has snowed alot. it started doing this about 3 hrs after i parked it for the day. we had been out in the snow that morning.
where would water be getting at the GEM from, or is it just moisture in the air that does it? if that is the problem, does that usually mean it needs replaced that moisture is causing it to act up, or do i just need to figure out how it gets wet and how to keep it dry?
ive read on here somewhere that a leaking windshield can be the culprit, dont think thats happening, but i will check it out. |
i've been looking into this GEM issue thru the forums, and it seems thats what my problem is. i appreciate the suggestion and the vast amount of info available here. i've had a few other problems that werent in my initial post that all seem to be related too. all of them are managable now that i know what to expect. i did find my windshield to be leaking, and perhaps the marker lights as well. windshield is replaced and i'll be dealing with the leaking lights this weekend.
my only remaining question to anyone whos dealt with this GEM trouble before is, will it get worse because its already damaged? if it just stays the same, or improves as one post suggested, i can live with it and spare a major repair. i just dont wanna have my keys get locked in a running truck or my windows stuck down when its 17 degrees and i'm on the turnpike 4 hrs from home (i actually had that one happen and it sucked!) or something like that. if anyone has any further insight i aprecciate it. if not, at least i took the opportunity to say how much easier this forum makes it to get to the bottom of a problem before i get a mechanic or the dealership involved. |
Just dry it out good and you should be fine..mine acts up every now and then so i just open and slam the door..works like a charm lol my last truck did too..
I had GEM issues, had to replace it when the remote didnt work anymore.... All good
now... |
i had the same problem when i was in colorado in the winter except with train horns lol had to go down 6 flights of stairs in the hotel to see what was going on lol,never did it again but i did get a new windshield after that trip and the old one was leaking
