Cold weather fuel leak????? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-15-2010, 12:46 PM Thread Starter
I have a 99 7.3 and it with 270,000 on it and runs fine. But the other night the temp got down to 25* which is bs in fla. I went out and started my truck to let it warm up and when I came back out I saw fuel on the ground. So I looked under it and it looked like it was coming from a small tube by the timing cover on the passenger side. What is this tube and is it a sign of some thing going bad? It wasent a ton of fuel but enuff to notice it.
CEMotorsports is offline
post #2 of 2 Old 12-15-2010, 04:47 PM
that is what you need
Separator Valve Rebuild
here is what i used
Replacement O-rings for Ford Diesel Engines
i took me 30 minutes
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
