Truck did not want to start this morning... - Ford Powerstroke Diesel Forum
Old 12-13-2010, 03:24 PM
Well the temp on the mirror said 6deg this morning when I tried to start my 2000 SD. It took 3 cycles of the key for it to finally start and ran pretty rough for about a minute and smoked alot. Truck has new stancor relay and about 128,000mi. I did not have the truck plugged in and it has been 3 days since it ran last. What temp should the truck start unassisted at? I have to check the glow plugs and see if I have some bad ones.
Duane
Old 12-13-2010, 04:00 PM
With a good GP system, they should start down to 0 with no problem, they just might not like it. Sounds like yours is in good shape. I don't even try... mine is plugged in below 30-35 degrees. Helps the truck with everything being warm, easier starts, less wear and tear on stuff, and nearly instant heat.
Old 12-13-2010, 05:55 PM
You should just plug it in. But new glow plugs wouldnt hurt...
Old 12-13-2010, 06:04 PM
yeah my advice is keeep her plugged in prob nothing wrong with it powerstrokes start alot harder in cold than a cummins or duramax ... ive got an 07 6.0 and i keep it plugged in at work and any where it sits for long enough to get cold... if i dont itll still start buy it shakes rattles and rolls the gray smoke for a min till it blood gets pumpin
Old 12-13-2010, 08:41 PM
Are you running synth or dino oil? I found that with the 15-40 it would start much harder than with a 5-40 at temps like that. If it was that cold a lot, I would be plugging it in, too... faster heat!!
Scott
Old 12-14-2010, 07:26 AM
Powerstroke Junkie
First of all a 7.3 should start without being plugged in at negative 20 degrees. Will plugging it in help? Of course. If it get's that cold where you live you should also switch to a lighter weight oil, this in itself makes a huge difference. You need to ohm your glow plugs to see which ones are bad, if any. I have a write up at the top of this section on how to troubleshoot your GP system.
PM me if you need any help.
NCH
Old 12-14-2010, 07:38 AM
yeah my truck hated starting yesterday morning. It was -4 degrees.
Old 12-14-2010, 04:17 PM
Thanks for the input. I just changed the oil and used dino 15 40. I dont drive the truck on a regular basis so its not realistic to plug it in for days at a time. How long does it take to warm the truck up with the block heater. If I plugged it in like 2 hrs before I started it would that be enough?
Thanks
Duane
