Fuel gauge/ tank questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-13-2010, 02:39 AM Thread Starter
I am new to the diesel truck world. Just bought a 00 crew/ short, 4wd/ 6 speed that is bome stock. Only problem with truck is the fuel gauge doesnt work, always reads full. Have not checked, but assuming it is the sending unit, where would be the best place to buy a replacement? Partsguyed has it listed for about $130 if I looked it up right?
Also, while in the tank, figured I would harpoon it and do the hutch mod. Only question is on the hutch mod. Why not just remove the plastic pickup all together and make a stainless tube extend to the bottom of the tank? And while adding a pre pump filter, why not the glass see thru type with disposable elements?
Just thought I would throw these out there and gett all of my stufff together, I only want to go into the tank once.
Edman87k5 is offline
post #2 of 7 Old 12-13-2010, 05:21 AM
It is possible for the float to be stuck in the full position. It happened to my dad's truck and I have seen a couple people on here that it has happened to.
2001 F-250 Lariat SC LB
130,000 miles
Bone Stock (for now)
raw109 is offline
post #3 of 7 Old 12-13-2010, 06:22 AM Thread Starter
I thought of that, but it's doubtful since it has been that way for quite a while. I figured I would open the tank before ordering the sending unit, but wanted to have annidea of where to get one so the truck doesn't stay down any long than necessary.
Also, on the hutch. Wouldn't be a problem using swagelock fittings would it? Wouldn't they actually be better?
post #4 of 7 Old 12-13-2010, 04:34 PM Thread Starter
Anyone have any input?
post #5 of 7 Old 12-13-2010, 05:10 PM
mine was stuck and the rubber gasket was out of the groove so it was leaking every time i was getting a full tank
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #6 of 7 Old 12-13-2010, 06:38 PM
Roc87's Avatar
When I was reassembling after doing the harpoon mod, I didnt get the connector plugged all the way in & the gauge read full.... So, maybe your connector above the fuel tank isn't getting a good connection?
'01 F250 7.3 PSD 4x4 EC SB. AFE Stage II, Banks 4" turbo-back, turbo housing & IC, Wicked Wheel 2, Rosewood 160cc/80 Single Shot Injectors, Beans Tunes, OilGuard bypass, Riffraff FRX & HPX, Zoodad, Harpoon, '04 18" rims, '07 Front & '08 Rear.
Roc87 is offline
post #7 of 7 Old 12-13-2010, 09:26 PM Thread Starter
I should have a chance to at least check the wiring and such around the end of the week. I would love for it to be as simple as a unplugged connector!
