Dumb question about gvw
ok so this may sound dumb but, what exactly is gross vehicle weight? is it the weight of the truck plus a load equalling the max legal weight? or is it the weight the truck call haul. i know towing and hauling are two different ratings. never really understood all the gvw stuff.
your gvw is the weight of the vehicle but your gvwr is going to be the maximum legal weight of the vehicle loaded, that includes the weight of the vehicle and cargo / tongue weight if hauling a trailer.
thanks for the info. and tongue weight is also determined on your trailer hitch rating too right? how do you determine how big of a trailer you can pull either conventional or 5th wheel, or my tow rating?
It's like this. You have four major weight ratings. Two of which come into play on an F250.
GVWR is the max amount that the four wheels on the truck can weigh. So, if you have an f250 that weighs 7,000lbs dry, you can add 1800lbs of extra weight to the truck (cargo, passengers, fuel, and the force from the trailer pin weight). Because the GVWR of an f250 is 8800lbs. GCWR is the maximum amount that the truck and its trailer can weigh. On an F250 this is 20,000 lbs. GCWR-GVWR=MAX TRAILER WEIGHT (11,200lbs) The other two ratings are axle ratings. You wont really have to worry about these on a 3/4 ton truck. On a gooseneck trailer pin weight runs between 14% and 20% of the trailer weight, so if you have the same 7000 lb truck, the most your pin weight can be is 1800lbs - (cargo, passengers, fuel). So realisticly lets say 1400 lbs. A 1400lb pin weight is about a 9500lb trailer. On a 3/4 ton you're going to hit the GVWR long before any other rating on the truck, ESPECIALLY with a diesel. I think I'm blabbing now... if you have questions let me know... Sorry for the long post. Last edited by partsguy84823; 12-09-2010 at 08:29 PM. |
I dont know the answer to your question but i'll tell you these trucks will move alot more than they're rated too, just do it smart and be careful about it. thats all i gotta say.
What he said is absolutely correct concerning the terminology although my GVWR is 10,000 lbs on my truck.
Single wheel f350s go from 10,100 to 11,500 Dual Wheel f250s go from 11,800 to 13,000 PS I looked these up for a 2005. My '03 CCSB 2wd 7.3 is sticker rated at 8,800... Either way the concepts still apply. Last edited by partsguy84823; 12-10-2010 at 05:38 AM. |
^ well put by all, cab chassis trucks generally are a bit higher, like mine is 12,500.........thus (at least in Co) means I have to stay on truck roughts
but most of the time I dont.
