Winter embarrsment
After school, I went to start my truck, and it would just crank and crank I stopped recycled the key. Did the same thing. Did it three times. Then started praying. It finally started. It rolled the white smoke out the stacks for a few seconds. When i was cranking on it, it would blow white smoke too. It's done this before but only when I didn't plug it in over night. It was like in its 20's today. Last winter I never had this problem. This is really irritating. I put two new battiers in it a few weeks ago. Now, I don't want to shot gun this. So if anybody can give me an educated answer I would really appreciate it.
Thanks |
Check your GPR, if it's ok then it's probably glow plugs...
I am a freaking retard! How do I switch it over to to the 99 to 03 thread?
I've been thinking about that. how do you check it? multi-meter?
Agreed. The white smoke makes me think so.
If it does test out to be the gpr, look into the Stancor 586. It's a better replacement. ______________ Oh, thanks to Superduty4x4 for this post on testing gp's: You can ohm check the GP's without pulling the valve covers. The connectors are arranged as such: GICIG G = glow plug I = injector C = injector common ground To test the glow plug measure ohms between each G pin and a good ground. Should be between 0.2 and 2 ohms. Open (no resistance, 0 ohms) means a bad glow plug. Just touch the pins inside the valve cover connection with the lead on your multimeter. Last edited by retmotor; 12-09-2010 at 03:39 PM. |
I don't think the volt/amp meter will move on a Super Duty. All the gauges are like idiot lights. Just take a test light and test the relay. Turn the key on and if both sides (large post) of the relay cause the light to come on, relay is good. If only one post causes the light to come on, bad relay.
ya mine did that last winter, put new glowplugs glowplug relay and wiring harnesses and it does fine now. plus I put all new injectors in it
Troubleshoot with this first though: Winter Operation, Hard Starting, Hissing Sound Etc...
Definitely sounds like a GPR problem, if not it's your gp's. If it's your GPR, this will inform you on what to do: Stancor Relay Mod!! |
