7.3 Rebuild - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-05-2010, 07:50 AM Thread Starter
nate8809's Avatar
7.3 Rebuild
So I have replaced the motor in my 2000 f250 and I'm getting ready to rebuild the old one and I have it torn to the block pulled out and shatterd/partially melted piston..this. all started when my oil pressure regulater went out but anyhow all the other cylinders still look good still has the hatching on the cylinder walls but that on its scared up pretty bad and trying to figure out what the best rout would be bore it and sleeve it or just use bigger pistons? I know that you can boree it to much cause the cylinder walls aren't real thick at all so I'm open to suggestions......and are ther any numbers or anything stamped on the block anywher that might tell me when it was made or the type of internals are in it....cause I've been told the 99 was the last year of the 7.3 to have stock forged internals........
nate8809 is offline
post #2 of 4 Old 12-05-2010, 07:58 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Somewhere in 01 was the last time they used forged con rods. There's a list of serial numbers here that says which ones do and don't have em
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 4 Old 12-05-2010, 08:01 AM
diesel firefighter's Avatar
subscribed
im going to be starting this same project with in the next few months
03 F-350 Crew Long Bed 6.0 DUALLY
05 Harley Davidson conversion
Mbrp Exhaust
K&N air intake
HIDS in the headlights 6k also in the fogs 6k
Switchback LED turn signal bulbs
Other Rides/Projects
1979 Ford F-250 (project truck)
1944 Willys MB (Dads toy)
diesel firefighter is offline
post #4 of 4 Old 12-11-2010, 11:50 PM
7.3powerstroke99's Avatar
Subscribed. Im planning on rebuilding eventually. What brands were you going to go with for parts: piston, crank ect.
7.3powerstroke99 is offline
