Metal in fuel filter bowl - Ford Powerstroke Diesel Forum
post #1 of 16 Old 12-02-2010, 07:26 AM Thread Starter
dieselcrawler's Avatar
Quoted: 23 Post(s)
Pulled the truck in the garage the other night, smelled fuel. Was dripping out the water drain tube, traced the issue back to the fuel/water drain o-rings... in the process, I decided to change the fuel filter, was way over due. When I pulled it out, I found metal shavings in the bottom of the filter bowl. Should I be worried? I think so, but maybe someone would know if this is a major problem... my only guess is the fuel pump is on it's way out... and shavings are ending up in the filter bowl. Truck still runs fine...
Help... any ideas?
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #2 of 16 Old 12-02-2010, 07:33 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
ouch! I would start be cleaning it real good and go from there, do an ohm test on the pump, i would guess. I will leave this one to the tech's. but would like to know cause I dont want that to happen to me and know what it is if it do.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 16 Old 12-03-2010, 02:07 PM Thread Starter
Quoted: 23 Post(s)
I got as much of the particals out as I could with a turkey baster I stole from mom when I went down for dinner that night, but not all of it came out... I figure if I couldn't suck it out with the baster, the fuel in there wouldn't pick it up eather. And the new filter should protect the system down streem from there...
Any other comments out there?
Greg
Semper Paratus
post #4 of 16 Old 12-03-2010, 04:44 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
How 'bout a magnet in there?
NoRalPh is offline
post #5 of 16 Old 12-03-2010, 08:56 PM Thread Starter
Quoted: 23 Post(s)
I guess a magnet would work if the metal is steel... didn't think of it at the time.
Removal of metal particals not the real issue, though. Cause, however, would be good to know... Where else, besides the fuel pump, could the metal come from?
Greg
Semper Paratus
post #6 of 16 Old 12-06-2010, 08:48 PM
wingnuts514's Avatar
magic elves may have sprinkled it in there...
e99 f250 ccsb, looks stock...
she calls it my other girlfriend
wingnuts514 is offline
post #7 of 16 Old 12-09-2010, 02:40 PM Thread Starter
Quoted: 23 Post(s)
geesh, why didn't I think of that????
Greg
Semper Paratus
post #8 of 16 Old 12-09-2010, 04:56 PM
I know it's blasphemy around here, but lets see some pics of the chevy, I have an 84 as well.
post #9 of 16 Old 12-09-2010, 05:10 PM
artsamm's Avatar
Make sure you rinse out the turkey baster maybe once!
artsamm is offline
post #10 of 16 Old 12-09-2010, 06:19 PM Thread Starter
Quoted: 23 Post(s)
We're a true die-hard diesel family... almost have mom talked into deep frying the turkey in diesel, instaid of veggie oil... figure if you can use veggie oil to run your truck, you should be able to deep fry a turkey in diesel...
Naw, I told mom she wasn't getting it back, I've wanted a baster for the garage for a while... now I got one!!!
Greg
Semper Paratus
