Fuel leak issue...quick question. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-02-2010, 05:33 AM Thread Starter
So I just replaced my fuel filter. It was the old replaceable filter type, and I put a new WIX spin on filter on.
I have an irritating leak now. I don't think that it even stops when the truck is warm.
My thought is it is the fuel filter drain valve. I have done some searching, and it seems like that might be an issue.
Anybody have any suggestions?
Thanks.
2000; F250; 7.3; 2wd; manual tranny; extended cab; 121k miles
John316 is offline
post #2 of 10 Old 12-02-2010, 05:37 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
While running, see any flow? Get like a paper towel and clean it up and watch it while running.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 10 Old 12-02-2010, 06:03 AM
STANGMAN893's Avatar
I would lean towards the drain valve.I sold four this week alone at work.Can't keep up with them but all started around the same time.
STANGMAN893 is offline
post #4 of 10 Old 12-02-2010, 06:14 AM
PowerstrokinIt F250's Avatar
mine has the same problem. fuel pools up underneath the turbo and leaks out at the bottom of the engine. I stuck a mirror back there and its leaking from the fuel pump. The pump is around 100 bucks, but its a real pain to replace. I just left it the way it is and it still leaks it wont hurt anything it will just leave spots on your driveway until you get the money and time to fix it, if thats your problem, but thats the first thing i would check on a 7.3
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #5 of 10 Old 12-02-2010, 06:49 AM
Zaairman's Avatar
Quoted: 12 Post(s)
Super Dutys don't have a fuel pump on the motor like the OBS trucks.
John, WHERE is it leaking?
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #6 of 10 Old 12-02-2010, 06:53 AM
Adam-Arc's Avatar
If you played with the drain valve at all I would start there. Look at Guzzle's site for orings.
97 F350 CC 4x4 Auto Welding Rig
Steamfitters Local 475, Newark, NJ
IDM mod/Homemade CCV/10k/6637/3"dp/4" exhaust/no cat/muffler
Adam-Arc is offline
post #7 of 10 Old 12-02-2010, 07:35 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I just had to replace my drain valve the other day.... new valve with o-rings (made it a really easy, quick job) from Ford was about $62, I will replace the o-rings on my old one, leave it on the shelf untill one of the other 3 or 4 PSD's I help maintain need it... the dealer parts guy told me that the valve it'self will sometimes crack, and he had the whole valve in stock, not the o-ring kit, so that's what I got, needed it RIGHT NOW kinda deal...
Good luck...
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #8 of 10 Old 12-02-2010, 02:53 PM Thread Starter
Thanks for the help, guys. First off, I took Jarrod's advice. After it is warmed up, it wouldn't drip. It was mostly leaking out between the bowl and the valve assembly.
So I took a guess and installed a new drain plug assembly. Oreilly had one for 42, and they didn't have a rebuild kit. Taking the old one out was a huge pain, mostly because the old screws were corroded, or something. When I finally got them out, I installed the new one, which was a breeze. I will know by tonight, probably, if that fixed it. I sure hope it did!!!
Thanks for the help, gents.
John316 is offline
post #9 of 10 Old 12-03-2010, 07:03 AM Thread Starter
For anybody that wants the part number for that shutoff, here it is.
Dorman #904-202 cost $42.
Thanks again for the help.
John316 is offline
post #10 of 10 Old 12-06-2010, 05:00 PM
Josh99's Avatar
Mine was doing the same, Just find 2 viton o rings for the separator valve and change them. google it and there are a bunch of kits and directions. I got my o rings for 57 cents on ebay. Make sure you get viton they are black or brown. Also make sure you have a good gasket on the filter, and that there is only one not an old one stuck from the old filter cover.
- Zoodad
- Wicked Wheel (kills MPG)
-4" straight pipe dumps in front of rear tire
- Tuned by Power Hungry Performance
- Cold air
- Custom brush guard/winch mount
- Limo tint
- CB
- JVC head unit
- Warn Hubs
- 6637
- 45k Tru Cool + stock
Coming soon-
- 16k Warn winch/air compressor
- Leveling springs (WTB!!)
- Tranny build
- Forged rods
Josh99 is offline
