how to fix oil leak under high pressure oil line
does anyone have a guide/diagram of how to fix an oil leak under the high pressure oil line?
there is a quite a lot of oil leaking, in the valley. i would like to be able to fix this asap. thank-you. |
o-ring kit
I went to Ford bought the O-ring seal, takes less than 15 min. to install.
f |
I'm in the process of replacing the O ring on the end plug port of my HPOP (2001 F250 7.3 diesel) the instructions say to clean and dry the port before installing the new O ring. How do you stop the oil to clean and dry the port???
I did not replace the two discharge fittings because they didn’t leak. Thanks in advance for any help. Bruce |
Just had mine fixed, turned out the plug was a bit loose. After it was tightened up, no more oil leak. This was the plug under the HPOP lines.
Thanks for the reply. When I went to loosen the plug on my HPOP, I realized it was also loose and probably why it was leaking. I had already purchased the O ring kit so I was committed to doing the job. I realized the oil was running from the reservoir which holds about a quart of oil. So I wiped out the port the best I could and quickly installed the plug with the Loctite on it. I ran the truck today and no leaks.
