Oil on top of Engine - Ford Powerstroke Diesel Forum
Old 11-28-2010, 11:21 AM
I've got an 01 f250. It always seems to have oil sitting on top of the engine(kinda under the fuel filter and turbo). It never seems to be enough to drip down the motor to the driveway, but there is always oil on the top of the motor. Any help would be great
Old 11-28-2010, 02:01 PM
first check the hpop area(thats that thing there next to your fuel filter) then if thats not it it may be pedestal orings slowly giving out.. but it seems slow enough not to be dripping??
Old 11-28-2010, 02:04 PM
Thanks Ill check those out.
Old 11-29-2010, 04:45 PM
I had the same problem. It ended up being several things.
1. Leaking valve cover gaskets
2. Leaking intake boots
3. Leaking hpop crossover ends
4. And finally I got hornet's bypass setup.
And now no leaks
