custom tunes - Ford Powerstroke Diesel Forum
Old 11-26-2010, 08:27 PM
custom tunes
hey guys i keep hearing about custom tunes. i have the dp f-5 switch with just reagular tunes. i saw that they have custom tunes.when i talked to jody he said that he can do custom tunes. my question is my truck is just running stock turbo and injectors. can i run a custom tune or are they ment more for higher power rigs? ps i think i am running a stock turbo. it says garrett on it.i seen a stock turbo of of a 7.3 once and it did not say garrett on it. i am pretty sure it is the stock turbo.
Old 11-26-2010, 09:50 PM
You can run custom tunes on whatever. You basically tell them your setup and they will tune it to best fit your needs and current mods you may be running.
Old 11-26-2010, 09:58 PM
sweet thanks one more thing. what is a zoodad?
Old 11-26-2010, 10:01 PM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
zoodad is holes drilled to let more airflow
use the search feature to find more info on it
