rear differential seal - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-24-2010, 02:33 PM Thread Starter
Ive searched and looked around and I can find any information on replacing the rear differential seal... Thanks for the help..
Ouch is offline
post #2 of 9 Old 11-24-2010, 04:13 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
You need to buy some RTV. There isn't a seal.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 9 Old 11-28-2010, 02:43 AM
Nightcrawler's Avatar
Yes there is a seal. Mine leaks slightly. I have the new seal but couldn't get the nut undone. You have to take the prop shaft off. Mark the nut & threads then undo the big nut. When I tried I ended up just moving the truck by turning the nut. I still have to do this job, but will have a go next year now as it don't leak to bad.
01 F350 4x4 Lariat Super Duty LE. Dually. Hypertec system, AFE Induction kit, Rebuilt 4R100 with valve body & TC upgrade, 2x Trans coolers, Stacks & V3. Over the other side of the pond & yes my truck is left hand drive. Not sure why everybody asks me that. Just imported an awesome 06 6.0 Dually long bed. Just got to sort some stuff to make it leagal here...
Nightcrawler is offline
post #4 of 9 Old 11-28-2010, 07:19 AM Thread Starter
I found some step by step and info on another page. Thanks.
Ouch is offline
post #5 of 9 Old 11-28-2010, 07:55 AM
O.I.F. Combat Vet 11B
what seal are you talking about?
to op, I think some sell a gasket for the rear diff but trust me you are better off using black rtv sealant. The gaskets have been known to leak where the rtv doesn't.
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #6 of 9 Old 11-28-2010, 08:01 AM
topdwg's Avatar
RTV, trust me. I used the seals and they are crap...
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #7 of 9 Old 11-28-2010, 08:56 AM
late_99_PSD's Avatar
Quoted: 10 Post(s)
Hold on, which seals are you talking about. You have a pinion seal, a seal on each hub, and the rear cover.
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #8 of 9 Old 11-28-2010, 09:01 AM
Mikey's250's Avatar
Just use RTV and dont worry about it. I used the red because thats what I had at the house. Just let it set before you put the oil back in. I let mine sit over night and hasnt leaked a drop.
Mikey's250 is offline
post #9 of 9 Old 11-28-2010, 04:42 PM Thread Starter
I picked up some red. hoping to have some time after work tomorrow to scratch this off the todo list..
Ouch is offline
