Coolant Change / Engine Block Plugs - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-24-2010, 08:32 AM Thread Starter
I'm changing the coolant in Big Blue. Noticed that on the driver's side of the engine block two 1/4 inch female plugs. The top one is for draining coolant from the block but what is the lower one for? Haven't found it's purpose in any manual, yet.
Phyrefyter is offline
post #2 of 4 Old 11-24-2010, 09:14 AM
Stroken7.3's Avatar
If the lower one is just above the oil pan it is the inspection hole used for looking to see what rods your motor has.
2001 F-250, 6 speed trans, BDP Tunes, Autometer Ultralite gauges
Stroken7.3 is offline
post #3 of 4 Old 11-24-2010, 09:26 AM Thread Starter
Must be for a bore scope. Thanks for the info.
post #4 of 4 Old 11-24-2010, 10:34 AM
Stroken7.3's Avatar
No problem.
