Should I do all 8 glow plugs? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-23-2010, 07:07 PM Thread Starter
Question Should I do all 8 glow plugs?
I tested my glow plugs, on the drivers side, I have 3 that test open and 1 that tested at 11 Ohms. On the passenger side, I have 3 that test between .5 and 1 Ohms, and 1 that tested 4 Ohms. Is it worth taking the valve cover off on the passenger side for that one? I am guessing if I change the 4 on the driver side, truck will start pretty easy? I guess I could always do the 4 this week, and see how it starts after that. Would I be hurting anything to leave the passenger side as is with one bad if it starts easy after doing driver side? How long should I expect it to take to do one side? any hints to make it easy? my truck has 163,000 miles, should I replace the gasket also since I am in there? do they wear out or get brittle?
thanks
Mike
2003 7.3 crewcab shortbed
mprobst is offline
post #2 of 7 Old 11-23-2010, 07:10 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
yep. always replace them in a set.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 7 Old 11-23-2010, 07:11 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
do them all, and only need the gasket if you break it/it is bad. let us know how it goes.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 7 Old 11-24-2010, 06:01 AM
Stroken7.3's Avatar
Do them all at the same time.
2001 F-250, 6 speed trans, BDP Tunes, Autometer Ultralite gauges
Stroken7.3 is offline
post #5 of 7 Old 11-26-2010, 12:45 PM Thread Starter
Smile
It took me 6 or 7 hours, but I finally got my glow plugs changed , now truck starts on the second attempt instead of the 20th or 30th. The little breather thing on top of the driver side valve cover, what size or where do I get the orings for that? mine are all stretched out and need replacing, the guy at the parts store could not find a part, and when he took me back to look at all the orings, they were all round, none of them had a triangular cross section like the ones that were there. Do I have to go to the dealer to get this part?
mprobst is offline
post #6 of 7 Old 11-27-2010, 06:31 AM
got mine at the dealer for 2$ for both
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #7 of 7 Old 11-27-2010, 08:35 AM
O.I.F. Combat Vet 11B
Replacement O-rings for Ford Diesel Engines
you can find them here among lots of other great stuff
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
