Time for a new Hpop?
I finally got around to doing some datalogging on the icp. What do you experts think about my hpop? Time for a new one? Also would these low numbers maybe cause my smoke issues on accelerating from stops. It also smoke kinda gray while doing these runs from 60-90. I think I have read somewhere that a weak hpop will cause excessive smoke issue.
![]() Time Injector Control Pressure (PSI) [0.00 - 5076.32] Time Injector Ctrl Pres DC (%) [0.00 - 100.00] Time Vehicle Speed (MPH) [0 - 131] 05:34:00.562 1396.02 05:34:00.734 32.81 05:34:00.890 63 05:34:01.078 1772.74 05:34:01.234 35.54 05:34:01.390 64 05:34:01.578 1623.97 05:34:01.734 39.45 05:34:01.890 65 05:34:02.078 1648.3 05:34:02.234 44.92 05:34:02.406 67 05:34:02.578 1664.13 05:34:02.750 48.83 05:34:02.906 69 05:34:03.093 1675.45 05:34:03.250 52.34 05:34:03.406 70 05:34:03.593 1982.59 05:34:03.750 55.47 05:34:03.906 72 05:34:04.093 1988.25 05:34:04.250 57.81 05:34:04.421 74 05:34:04.593 1995.6 05:34:04.765 59.76 05:34:04.921 76 05:34:05.109 2014.83 05:34:05.265 62.5 05:34:05.421 77 05:34:05.609 2012.01 05:34:05.765 64.06 05:34:05.921 79 05:34:06.109 2025.02 05:34:06.265 64.84 05:34:06.437 81 05:34:06.609 2015.97 05:34:06.781 64.84 05:34:06.937 82 05:34:07.125 2013.7 05:34:07.281 64.84 05:34:07.437 84 05:34:07.625 1999 05:34:07.781 64.84 05:34:07.937 85 05:34:08.125 1987.68 05:34:08.281 64.84 05:34:08.453 86 05:34:08.640 1979.76 05:34:08.796 64.84 05:34:08.953 87 05:34:09.140 1974.11 05:34:09.296 64.84 05:34:09.468 89 05:34:09.640 1977.5 05:34:09.812 64.84 05:34:09.968 90 05:34:10.156 1970.71 05:34:10.312 64.84 05:34:10.468 91 05:34:10.656 1985.42 05:34:10.812 64.84 05:34:10.968 93 2nd run Time Injector Control Pressure (PSI) [0.00 - 5076.32] Time Injector Ctrl Pres DC (%) [0.00 - 100.00] Time Vehicle Speed (MPH) [0 - 131] 05:31:48.203 1220.67 05:31:48.359 19.14 05:31:48.531 65 05:31:48.703 1246.12 05:31:48.875 22.26 05:31:49.031 65 05:31:49.218 1992.77 05:31:49.375 34.37 05:31:49.531 67 05:31:49.718 1666.96 05:31:49.875 39.06 05:31:50.031 68 05:31:50.218 1920.37 05:31:50.375 44.53 05:31:50.546 69 05:31:50.718 2009.74 05:31:50.890 47.26 05:31:51.046 71 05:31:51.234 1990.51 05:31:51.390 50 05:31:51.546 73 05:31:51.734 1982.59 05:31:51.890 52.34 05:31:52.046 75 05:31:52.234 1988.25 05:31:52.390 54.68 05:31:52.562 77 05:31:52.750 1999.56 05:31:52.906 57.03 05:31:53.062 78 05:31:53.250 2004.09 05:31:53.406 59.76 05:31:53.562 80 05:31:53.750 2000.13 05:31:53.906 62.11 05:31:54.062 82 05:31:54.250 2007.48 05:31:54.421 64.84 05:31:54.578 84 05:31:54.765 1994.47 05:31:54.921 64.84 05:31:55.078 85 05:31:55.265 1983.16 05:31:55.421 64.84 05:31:55.578 87 05:31:55.765 1992.77 05:31:55.921 64.84 05:31:56.093 89 05:31:56.265 1989.38 05:31:56.437 64.84 05:31:56.593 90 05:31:56.781 2002.96 05:31:56.937 64.84 05:31:57.093 93 05:31:57.281 2011.44 |
What setting is this on with your chip?
Those numbers are very low, I dont see a single area where you are over 2050psi... I would look at IPR oring and injector O rings first, then go to the HPOP. if you can you can do a pressure test on the injectors, but you need some parts to do this. |
65% duty cycle at 2000 psi is a problem...
I am going to be pulling the ipr very soon and cleaning and putting new orings in it. As for the injector o=rings they are brand new with less than 3k on them. you said 65% duty cycle is bad, could you explain why. Still have a lot to learn....
OH, and this was with the chip on tw's street tune
I got that duty cycle in stock mode and it failed while driving.
So ya im gonna lean towards the hpop is bad. My icp was never above 1500 tho. and at that psi was 65% DC And while I was driving on the 16hr drive, I watched my psi drop down to 500 psi with dc at 65 99% of the drive. Just watched it die a slow nasty death. |
Replaced my HPOP with the Adrenaline, now with the extra power my trans slips
when towing... The new HPOP solved all the other issues I was having with the motor with reduced power. Just now the trans cant take it. BTS trip on Dec 3rd. |
ok, well I pulled the ipr , cleaned her up and put new orings on her. Guess I will find out tomm if she drives any different. Guess I will start saving for a hpop.
