Oil Pan Paint? - Ford Powerstroke Diesel Forum
Old 11-18-2010, 09:08 PM
Oil Pan Paint?
Well I have heard that the oil pans on these trucks tend to rust out. And I crawled under mine today and there is a little surface rust starting on it, and I want to stop it now. Ive heard POR 15 is the stuff to use, but how does it hold up to the heat? Or is there something else I should use?
Thanks,
Chris
Old 11-18-2010, 10:28 PM
drives a ranger
Send a message via AIM to kanuck15
POR is awesome crap. I think it takes heat pretty well. Never used it on anything like that but an oil pan doesnt get that hot in relativity to the motor. so you will probably be alright using it
Old 11-19-2010, 02:28 AM
POR 15 will work fine for a rusty pan. Mine is to the point where it is leaking & POR 15 wouldn't seal it. JB weld worked better for me. Get some on that pan asap. You don't want it leaking.
Old 11-19-2010, 02:51 AM
I have heard that is good stuff.
Old 11-19-2010, 09:14 AM
Thanks guys. Hopefully tommorrow I will get this done. And it isnt to point where there is any leaks or anything, just a lil bit of surface rust starting, and I want to stop it now.
Thanks,
Chris
Old 11-19-2010, 09:21 AM
Almostdunfukinwidit
POR 15 it then herculine it
Old 11-19-2010, 09:27 AM
There wont be too much heat for the herculiner?
Old 11-19-2010, 12:11 PM
mines leaking already.. just a few drops a day. think JB weld will fix it up?
Old 11-19-2010, 02:10 PM
drives a ranger
id use that metal filler, comes in a tube much like RTV but its what saved mine for now
