Boost Problems! - Ford Powerstroke Diesel Forum
Old 11-18-2010, 07:04 PM
Boost Problems!
Installed my Edge Insight CS this week and I noticed that when I stop on it in the 75hp setting i am only seeing 15-16 psi. That seems really low compared to what everyone else is seeing. Truck only has 69,000 miles. Do I have a leak somewhere? or is something getting weak?
Old 11-18-2010, 07:33 PM
how long you let it build for? with mine on 80 from a dead stop and i hammer down for jesus i build around 22, i had a kink in my line when i had that problem
Old 11-19-2010, 05:26 PM
I haven't mashed on it from a dead stop yet. Cruisin at about 25-30 mph then i'll give WOT. Only seeing 16 psi tops...
Old 11-19-2010, 09:24 PM
mine wont make max boost, empty, until almost hitting the rev limiter. with a manual boost controler, i can see 20-21 with the superchips. i did hit 20 hauling a 30 ft travel trailer up a hill w/o the superchips. before i changed out all the intake/intercooler boots, i was only seeing 15..... i did put all new dieselsite boots on.
Old 11-19-2010, 10:07 PM
With a superchips I can hit 22 lbs empty on the economy tune.
What you have going on does seem low. Have you checked all your boots?
Old 11-21-2010, 07:39 PM
Check my boots this afternoon and some of them had an oily residue on them. What does this mean? Sorry, first diesel i've owned.
Old 11-21-2010, 07:52 PM
Mine hits 22psi with no tune. Just intake, exhaust and the red line on the wastegate unplugged.
Old 11-21-2010, 08:09 PM
No worries, theres supposed to be a little oil/oily residue in them. The black piece that connects the 2 boots is actually what oils your turbo so there should be a bit more residue on the boot closest to the turbo and not a crazy amount on the boot leading to your filter housing.
Old 11-22-2010, 12:45 PM
So any ideas why i'm seeing only 16 psi w/ a TS chip?
Old 11-22-2010, 05:57 PM
check the wastegate rod, how much thread is still exposed, theres about 1.5" of threads on it, and some are way looser then others i have seen, I would hit 22 wot with a superchips in my manual. but it takes near redline to get there. also, the red line to the wastegate is unhooked and blocked off. mine hammers right to around 15-16 from a stop then goes up from there. also, load makes boost. give me a hill and i can SHOOT to 24# easy.
