No 4X4 - Ford Powerstroke Diesel Forum
Old 11-14-2010, 07:47 PM
No 4X4
Talked to a few different people an we have Narrowed it down to being a bad 4X4 Relay...
Where is this Located on mt 2002 F350?
Need help bad, before winter actually hits..
Thanks
Henry
Old 11-15-2010, 07:27 AM
you sure its not the huds or a vac leak? That is the norm. And even if you set the stock hub to lock, that does not mean its really locked! I had one that was locked and no matter what would not unlock. then the other was unlocked and no matter what I did would not lock. I replaced my stock POS hubs with some warn hubs. now they lock and unlock when I want them to and they stay that way!!
Old 11-15-2010, 07:42 AM
When the vac pump fails on these trucks don't we lose the heat controls, Defrost, floor, Vents, AC, an etc? Just what I have heard.
Thanks
Henry
Old 11-15-2010, 09:19 AM
depends. if there is a leak the hvac should work ok till you put it into 4wd. then typically the ac will switch to the defroster on its own. but just because the vac is working does not mean the hubs will really lock.
I would lock both hubs and pick up the front end. Spin a tire and the other one should spin the other direction. unlock one and that one should spin free., lock it and unlock the other and spin.
next with the truck in 2wd can you spin the front drive shaft with the front end on the ground? you should. Next put it into 4wd and you should not be able to spin the front drive shaft. it should be locked to the transfer case and the rear drive shaft.
Old 12-03-2010, 09:46 PM
Thanks for the responses, got enough time off work to get her in to a shop, turns out it was the Actuator its self, an the guy had a used one laying around... sorry for the slow reply...
Henry
