oil dripping from turbo - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-14-2010, 07:05 AM Thread Starter
I have a small oil leak. I get a small amount at the starter. I have been cleaning and believe i have found it coming from the up pipe where it meets the turbo Y pipe. Its wet around the bolt and the head of the bolt is wet. I have not done the ccv mod as of yet, Can the turbo's inner seals be leaking slightly causing this?
ARe the original turbos rebuildable? The truck runs well.
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 7 Old 11-14-2010, 07:10 AM
eric99f250's Avatar
Its probablythe pedistal orings leaking
2015 F350 CCSB Lariat!
Back after 6 longggggg years.
Mods to come!
Owner of E.S. Billiards
Billiard and Game Room Supplies
2000 F350 CCLB dually...sold
1999 F250 RCLB...sold
eric99f250 is offline
post #3 of 7 Old 11-14-2010, 07:24 AM Thread Starter
they wont leak from the up pipe gaskets. I suppose anything is possible. I recently replaced them. The metal flange arouns the pass side up pipe gasket is wet and oil on the bolt. The pedestal is dry.
melmount is offline
post #4 of 7 Old 11-14-2010, 02:45 PM
eric99f250's Avatar
check the ebpv i just went through and changed mine today and come to find out the ebpv is leaking:/
Mods to come!
post #5 of 7 Old 11-14-2010, 02:55 PM Thread Starter
thx, I have used a mirror as best i can, It really appears it coming from inside the trubo and out the up pipe gasket. There are seals in the turbo right? Oil flows thru it, thats why we have the o rings on the pedestal. That oil somehow circulates thru the turbo? I am wondering if i am at an early stage of these seals failing? Maybe its the ccv allowing oil into the turbo?
melmount is offline
post #6 of 7 Old 11-14-2010, 05:28 PM
99BEIGEPOWERSTROKE's Avatar
Can the CCV allow oil into turbo and if so what happenes when the oil in the intake from the CCv does get in the turbo?
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #7 of 7 Old 11-17-2010, 02:08 PM Thread Starter
anyone? can I rebuild these turbos? New bearings and seals?
melmount is offline
