Which one is fuel feed and which is fuel return - Ford Powerstroke Diesel Forum
Old 11-12-2010, 10:03 AM
Im having some fuel issues and was wondering if anyone could tell me out of the 2 lines/ports in the engine bay if the lower or upper is the fuel feed? I tried following the lines but they get turned around under the alternator and I cant tell which one is fuel feed. Im trying to finish my veggie oil conversion and this is holding me up.
thanks
Old 11-12-2010, 10:12 AM
The one on the top drivers side of the fuel bowl is the return line.
Old 11-15-2010, 12:51 PM
thanks. for some reason Im not getting any fuel out of the feedline.
Old 11-15-2010, 02:55 PM
Fuel pump running?
Old 11-15-2010, 02:58 PM
I think I might have it wired backwards. Im getting bubbles.
Old 11-15-2010, 02:59 PM
Sounds like you did.
Old 11-15-2010, 03:14 PM
it sounds like its working normal though but maybe its spinning backwards?
Old 11-16-2010, 06:42 AM
well went to switch wires around but its dummy proof since one lug is thicker then the other. I think I just need to bleed the air out of my lines
