STEERING BOX HELP!!!! - Ford Powerstroke Diesel Forum
Old 11-11-2010, 10:25 PM
So my trucks steering is getting looser and looser. Had the truck for 3 years now and the steering is really bad. How do I adjust the Steering box.
Thanks
Old 11-11-2010, 10:42 PM
ARMY MOM!!!!
Send a message via Yahoo to korg70kbc
yuck I need to know about this too....I do have a new-ish one sitting here to go in jic..... don't have a clue on how to do it, nor do I think I even want to know.....
Old 11-12-2010, 12:18 AM
If you from the top of the engine bay down at the steering box there's a locknut and adjusting screw on top (you might have to clean it up due the grease and dirt that collects there). Just loosen up the nut then use a allen wrench to adjust.
Old 11-12-2010, 02:54 AM
How much do you tighten the bolt down will it stop when its all the way adjusted or do you turn it little by little and keep taking it for a test drive?
Old 11-12-2010, 03:03 AM
Well guys I took my truck in for Hard start and got a new FICM under warranty
plus my steering was real loose and I thought it was my steering box. Well nope It turned out to be
a Bad center drag link that was causing my steering to be as loose as a goose. Something to think or
look at when you have a loose all over the road steering ..
Loose steerin Fix
Old 11-12-2010, 03:51 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
check all your steering components first because if you adjust the nut and dont need to you can break the box.
Old 11-12-2010, 04:08 PM
ok which one is the drag link. is it the one that goes from the frame to the front diff? also i have never adjusted this either not sure if it makes a difference or not.
Old 11-12-2010, 06:52 PM
ARMY MOM!!!!
the one I broke not a easy task
Old 11-13-2010, 10:09 AM
which one is it tho?
Old 11-13-2010, 04:47 PM
ARMY MOM!!!!
the upper one....
