thinner weight oil vs ipr values? - Ford Powerstroke Diesel Forum
Old 11-11-2010, 03:18 PM
I have been reading up a while here on going to a 10-30 or something a little lighter weight for winter. Have any of you that switched over taken a look at your Injection Pressures on a scan tool? If so how does the thinner weight effect them?
Old 11-11-2010, 08:17 PM
I ran 10/40 for years in Arizona and in Alaska (since 2000) I ran 5/30 year round but switched to that Valvoline Cummings synthetic last winter, I think it’s a 10/40. I never saw any notable difference in pressures with a worm motor. On a cold motor cold starting you get more pressure and that is why they start so much better. For cold start the difference between 10/40 and 5/30 is amazing but with synthetic they start first hit at 20 or 30 below without being plugged in so it’s well worth the money for me here in Alaska. I broke down and went synthetic after having to nuke a gallon of 5/30 in the microwave one morning so it would pour, synthetic is not nearly as affected by cold or hot temps.
Old 11-11-2010, 08:33 PM
Cynic
Your motor has worms? I'd get something for that....
Unless you are below 0 degrees, just use the standard oil and plug in your truck at night. Or, bend over and pay the $$$ for the 5w-whatever synthetic.
My truck started the same in Milwaukee area (Jesus.. was it cold), as it does here in Texas. Just cycled my glow plugs, and bam.. fires right off. Let it idle a few minutes and since the truck was plugged in, the heater was already warming up the truck. Standard 15w-40 is the only thing that was been run in my truck.
