Fuse 19 Trouble - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-11-2010, 09:08 AM Thread Starter
ridiculously_necessary's Avatar
Fuse 19 Trouble
I have a friend with a 2000 F350 who keeps losing fuse 19, several times a week to several a day. i havent seen the truck and dont have an SD myself. he loses part of the dash cluster, and a few other items that i dont recall at the moment. he did say something about the door dinger not shutting off or something. i figure its a short somewhere. the truck runs just fine though. thoughts or expirience with 19?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #2 of 6 Old 11-11-2010, 10:06 AM
Quoted: 144 Post(s)
Feedback Score: 3 reviews
I think that's a symptom of the dreaded OD switch wires, under the column, rubbing through. Take the "clamshell" from around the column, behind the wheel, apart (long screws from underneath) and inspect those wires. They commonly rub and short....
NoRalPh is offline
post #3 of 6 Old 11-11-2010, 11:34 AM Thread Starter
well do, thanks man!
keep chiming in if you all have other ideas.
-Matt
DIY 6637
Marinco Mod
post #4 of 6 Old 11-22-2010, 07:47 PM
I had the same problem yesterday. Hit the overdrive button to down shift and bam....lost all power and the guages. Read the owners manuel and fuse #19 seemed to be the problem. Sure enough fuse #19, 10 amp, blew. Put in a new one a got home. Power Stroke expert here says it is those wires under the column. Truck in the shop now.......see what happens.
Dale Ballard is offline
post #5 of 6 Old 11-23-2010, 07:32 AM Thread Starter
good to see soemone else with the problem, let us know what happens!
-Matt
DIY 6637
Marinco Mod
post #6 of 6 Old 11-25-2010, 08:33 AM
Our Power Stroke, Ford expert around here, said this is a very common problem. He said he had fixed at least 500 of these. He replaced the shift lever. Total cost, $130. Great if it works.
