Queastion on Tire Size - Ford Powerstroke Diesel Forum
Old 11-11-2010, 05:58 AM
My truck is in the sig it dont have a lift or leveling kit. the tires on it now are 285/75 r16 and i was just wondering what is the biggest i can go before i need to do a lift or get bigger wheels. so basically whats the biggets tire i can fit on a stock tire/truck.
thanks
mike
Old 11-11-2010, 08:06 AM
C-5 & C-17 E&E Specialist
I'm sure someone will correct me if I'm wrong... But I believe you can run up to a 305/70/16 without any rubbing issues...
Old 11-11-2010, 04:01 PM
what about spacers? do u need them for 285 75 16
Old 11-11-2010, 04:41 PM
Im running 285's on my stock 2000 and they rub a little at full turn but they are on a 10in rim.
Old 11-11-2010, 05:25 PM
Widest you can fit on a stock rim is 285/75/16. After that you need different rims.
Old 11-12-2010, 03:44 AM
so basically i cant go up to a 305/70 R16 i have to stick to my 285/75 R16 on the stock wheels
Old 11-12-2010, 06:10 AM
Some guys do, but I think it's too wide.
Old 11-12-2010, 06:52 PM
IBEW Journeyman Lineman
I'm running 305/70/16s on my stock rims. I have a leveling kit and it doesn't rub except for at full lock they will rub the leafs a little. The tires look a little big on the stock rims but don't give me any problems. Even wear and smooth balanced ride. I also run 285/75/16s and they don't rub at all.
