Some new issues, need some info
Well I noticed a little coolant has been slowly dripping down the large hose under the pump. Its hard to tell where it's coming from, is this just the expected water pump failing?
I went out in a plowed field yesterday to sight in the rifles and I forgot to unlock the hubs. Tonight I notices a rubbing sound while making left turns.. I noticed the ends of the front ujoints on the right are hitting the grease fitting on the upper ball joint. Is this a sign of something worn out or just the grease fitting is too big? Would like to figure this stuff out before the snow flys! Thanks. |
Theres a weephole on the waterpump and it will start dripping when its going(If you're lucky, mine went poop all at once and just dumped gallons!) How many miles you have on that thing? they go between 150-160k usually. I had 162k ha.
It's right about 160k
158,300 miles to be exact. I guess I'm due.
Now what about the front hub? |
smaller grease fitting
