No Blinker? - Ford Powerstroke Diesel Forum
Old 11-07-2010, 08:35 AM
Question No Blinker?
Hey guys I have done a little research but not found much and was just wondering if any of you have ever come across this problem?
My right turn signal doesn't work? Parking light works and i swapped the bulbs to check to make sure both filaments are working and they are both good... all fuses are good too not that there is one for just the turn signal though the arrow on the dash also doesnt go on for the right signal and the back blinker blinks at a normal speed...
I have read that it could be the flasher? or the actual switch itself on the steering column...
Is there any good way to check these theories?
Thanks in advance for your help
Old 11-07-2010, 09:44 AM
Send a message via MSN to babs2972
Yes this happen to me and i thought it was in the steering column. it was the blinker relay,very easy to fix. But i had to get my relay at the dealer and it was $25. If you have around an 05 model and are sitting in your truck the relay is behind the little flip down glove box by your right knee. If you pull that door off it will be behind it and it is blue.
Old 11-07-2010, 09:45 AM
Let me know if you want me to post a picture or video link
did you check the blinker fluid??
just kidding...sorry
Old 11-07-2010, 12:42 PM
wait?? wheres the blinker fluid tank? i havent checked that yet
hahah jk but its okay one of my friends said that too, but hey its worth a try everytime i mean hell we had the guy at the local autozone looking through the computer for a piston return spring for like 5 minutes until he went let me ask my associate and his co worker laughed at him haha
but on a 99 where would the relay be?
thanks again guys
Old 11-07-2010, 02:08 PM
thanks again guys
:h ehe:
Old 11-07-2010, 02:10 PM
sorry cant help with placement onf the blinker
that was some funny %#@* you did to that guy...MANNNNNNN im still laughing
Old 11-07-2010, 02:12 PM
Send a message via Yahoo to nt99sd
blinker problem
mine has the same problem the cause is short wires in the column the wires pull out of the plug due to the tilt column either change the vconnection or use permatex on the wire ends.
Old 11-10-2010, 08:01 AM
anyone know where the relay is?
