EBP TUBE/SENSOR?
What are some symptoms of the EBP being clogged or having a crack in it? What will it hurt if it has a crack in it or is clogged? Also what are some symptoms of the sensor being bad?
Bump......
my tube had a big rust hole in it. when i put in a new sensor and tube, i gained back about 1or so mpg.... other than that i dont remember anything else that i noticed that changed.
I would like to know as well. Mine had a hole in it that I welded up untill I can order a new one. No leaks but doesn't look very pretty.
I got to look at my tube and it is actually broke in two. It is broke about 6 inches from the manifold. I was able to put a screw in the end of the piece that is attached to the manifold for now cause I have black soot everywhere from it being broke. Is that ok to do for now? I figure the sensor wasnt working anywhere and it will stop my exhaust leak. Sound good? Will it be bad to have it just plugged for now? Also I did go ahead and take the EBP sensor out and the end of it was plugged with soot and so was the tube that attached to the sensor. I think Im just gonna get a EBP sensor terminator. Then maybe leave the tube plugged if thats ok or get a new tube.
I have deleted my ebpv does a messed up sensor still effect my performance?
BUMP.......
