Air bag light - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-02-2010, 06:26 AM Thread Starter
35thls1ss19's Avatar
Air bag light
Hey guys i have been searching and searching! My air bag light is coming on with the code 32. Which is open driver side circuit? I have read clock spring maybe? But no one has said how to fix it? Any insight? thanks guys
Tow vehicle: 99 F350, Extended Cab, 8' bed, Tint, Light bar, 2.5 inch leveling kit, American racing 16x10 wheels, 33inch Mud terrains, black tool box, 09 SD Tailgate, DIY intake, 5inch exhaust to 6 inch tip, zoodad, foil delete, pyro, egt, boost on the pillar, DP 60tow, 80eco, 120race, 05 front end
Race Car: 2002 Camaro 35th anniversary LE SS, Heads, Big cam, N2O, 9inch.
Water fun: Formula 223LS 454BBC
35thls1ss19 is offline
post #2 of 3 Old 11-03-2010, 07:57 PM Thread Starter
no one ran into this?
post #3 of 3 Old 11-04-2010, 06:57 AM
Dunno what your pickup has for restraint stuff, but when I got my pickup, the switch in the seatbelt buckle that tells if you have it on was bad, so the dinger would go off whether I had the belt on or not. In my work pickups, I've always disconnected the connector going to the seat belt buckle to disable the alarm, so I tried it on my pickup. Unplugged the wires going to the buckle, and then my air bag light would come on in addition to the seatbelt dinger. Looked into it again, and I figured out that the seat belt buckle has a retractor built into it, made to work in conjunction with the air bag system. Plugged it back in, fished around for the right connector to make the dinger shut off, and everything was fine.
Now, no idea when they started putting those retractor systems in, mine's an '03. Also, no idea what code mine was throwing since I didn't have a reader yet.
tek9tim is offline
