Newb needs help with engine buy
I found a 2000 7.3l excursion limited, clean carfax, 160k miles. this is the oasis report---good buy for $13k?
FIRST OWNER------- new to 65,000 miles 16-MAR-2000; 3134 miles Cust Comments: CUST STATES TEMP GAUGE INOP Tech Comments: SENDING UNIT DIAG REPLACE INSTR. CLUSTER. PER HOT LINE, REPLACED TEMP SENDING UNIT 15-JUN-2000; 10,551 miles Cust Comments: CUST STATES TEMP GAUGE FLUCUATES AND IS INOP INT.. Tech Comments: SENSOR DIAG REPLACE COOLANT TEMP SENSOR AND CONNECTOR 15-JUN-2000; 10,551 miles Cust Comments: CUST STATES AC NOT COLD Tech Comments: DIAG DIAG PRESSURE TEST NO LEAKS, EV AC AND CHARGE ADD DYE 25-0CT-2000; 20,559 miles Cust Comments: CUST STATES TEMP GAUGE INOP Tech Comments: CONNECTION DIAG TRACE WIRING FOUND TERMINAL AT TEMP SENDING UNIT 05-AUG-2002; 44032 miles Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON DIED AND WOULD NOT RES TART THIS WEEKEND, WENT BACK THIS Tech Comments: DIAGNOSED AND REPLACED THE CAMSHAFT POSITION SENSOR 27-DEC-2002; 50,332 miles Cust Comments: CUST STATES THAT THE VEHICLE AFTER ABOUT 4 MILES IT LOADS UP AND HAS NO POWER,CHECK AND ADVISE Tech Comments: DIAGNOSED AND REPLACED THE EXHUAUST PRESSURE CONTROL VALVE AND THE BACK PRESSURE SENSOR, ALSO REPLACED THE INJECTOR 20-JAN-2003; 50,644 miles Cust Comments: CUST STATES THAT WHEN W ARM,LOOSES POWER, WILL NOT PULL ITSELF AND TEMP GAUGE IS NOT WORKING PRO PERL Y ITech Comments: DIAGNOSED AND FOUND THE PCM FAILING INTERMITENTL Y,REPLACED PCM TEST DROVE FOR 90Ml. NO PROBLEM REOCCURED SECOND OWNER----- 65,000 to 123,100 miles 29-JAN-2004; 66,060 miles Cust Comments: VEH NOT WARMING AFTER 20 MILES OF Tech Comments: DRIVING PER CUSTOMER REPLACED THERMASTAT ENGINE WARMS UP TOO 03-JAN-2005; 84, 777 miles Cust Comments: UNIT RUNS FOR 5 10 MINUTES THEN SHUTS OFF. Tech Comments: 84777 PERFORMED VISUAL INSPECTION CHECKED FUEL TOPPE D OFF OIL LEVEL CHECKED INTAKE RESTRICTION PERFORMED KOEO PULLED CMDTCS P0340 P0344 TEST DROVE MONITORED PlDS FOUND UNIT WOULD DROP RPM SIGNAL USE CAM SENSOR TESTER CAM SENSOR FAILED REPLACED CAM SENSOR RETEST DROVE. OK 5829 NOTE CHECKED FUEL MPG AT 63 MPH UNIT GETTING 14.2.MPG .5829 THIRD OWNER-- NO WORK DONE (123,100-123,500 owned 6 months) FOURTH OWNER--- 123,500-160,000 09-APR-2008; 137,751 .3 hrs for no work listed- TRX Code 07S57, internet says is for RECALL 07S57 INSPECTED CMP SENSOR BLA CK WITH GOLD BRACKET INSTALLED NEW CMP SENSOR ER RECALL." 01-DEC-2009; 65,258 Cust Comments: 09S09 RECALL, internet says for speed control deactivation switch |
cant help but sounds like its had some issues
It may have some issues but these excursions are getting harder and harder to find and are getting more expensive as there is less on the road especially with the 7.3
Doesn't sound to bad. Sounds like a typical dealership fixing it, none of that was real major stuff. The 7.3s did have that cam sensor problem.
Thanks for the looks...I guess my real concern is what might else go wrong. It seems like the big issues are done and the random breaks might occur.
