how do you take out the headlights? lol - Ford Powerstroke Diesel Forum
Old 10-30-2010, 08:00 PM
Okay goin to install my new lights tomorrow, dumb question,... how do i take the old ones out? lol is there a guide on here?
i know the turns is just two screws ive had them out before but not the headlights, is it that easy also?
Thanks
Old 10-30-2010, 08:35 PM
just a number
There are two clips on top that pull straight up.
Old 10-30-2010, 08:58 PM
the easiest way to change out the headlights is just use the adjusters for the headlights and turn them all the way out, then on the clips right by the fender, just use a flat head screwdriver and a small pick and some way pry that up and then your headlight should pop right now. If done correctly, it should take you less than an hour to do both sides
Old 11-01-2010, 05:46 AM
Hell, I am doing mine as well. Took them out last night and your right. Ya gotta screw the adjustment screws all the way out to get the headlight portion out along with the 2 clips. The hardest part for me since I am changing to a 1 piece light, getting the electric connectors off of the blinker and side light marker bulbs. will post up some pics when done!
Old 11-01-2010, 09:47 AM
well i took mine out and well the two clips that was easy didnt mess to much with adjusting just needle nose and they were out, it was that pesky little thing down int the bottom the part that is your up down adjustment on the inside getting that one out was a *****, not sure if theres a trick or not dad made a little deal outta wire and just finaly got them
