HPOP gauge wiring - Ford Powerstroke Diesel Forum
post #1 of 22 Old 10-30-2010, 08:01 PM Thread Starter
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
HPOP gauge wiring
Who has one of these installed?
No problem with the wiring in the cab, but...
When wiring to the HPOP, which sensor do you come off of?
The instructions are a little vague because the gauge works for fuel rail pressure also in several other vehicles.
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #2 of 22 Old 10-30-2010, 11:10 PM
i've been curious to see one of these gauges.. bump for your question. btw nice avatar..
Dietoremain is offline
post #3 of 22 Old 10-31-2010, 07:26 AM
chillls's Avatar
[QUOTE= btw nice avatar..[/QUOTE]
hu?
Dave
2002,7.3L,6sp,cc,lb,xmonitor,1705,zoodad,AFEstg2, wicked wheel,hpx ss line,straight pipe,325/65r18 mtz,kmc 18x10,6.5"procomp lift & track bars,firestone bags,viair 480,5g tank,train horns,70g transfer tank,leer shell,12k warn & hidden bumper kit,05-07 H-D headlights,35W 5K HIDs in head/fogs
chillls is offline
post #4 of 22 Old 10-31-2010, 07:29 AM
JSchuricht's Avatar
Just taps into the ICP sensor. Sinister diesel has a pigtail if you don't want to splice your harness.
JSchuricht is offline
post #5 of 22 Old 10-31-2010, 09:15 AM Thread Starter
Let's go B's!!!!
Southpaw's Avatar
The instructions I have didn't say which sensor. I assumed it was the ICP sensor like you said so that is the one I went to first. The wire colors matched the instructions so I figured I was good to go. I tapped into the factory wires and I got nothing. The SES light was on and there was power to the gauge, but the needle never moved once.
That's what prompted the question about which sensor I should use.
So if it is the ICP which two wires? The gray/red stripe is the ground, and the blue/green stripe is the other one I went to. Is that where yours is?
Dietoremain As far as the avatar...thanks bud
Chillls, The avatar is NOTW. Stands for: Not Of This World.
It is a clothing company based on scripture. Colossians ch.2 v.8
NOTW Clothing - Not of This World Apparel, T-Shirts, & Car Stickers
Chris
Southpaw is offline
post #6 of 22 Old 10-31-2010, 09:26 AM
WisconsinDiesel's Avatar
Easiest was to monitor it is probably with a Scangauge2. Just plug it into the OBDII and you can monitor all sorts of things, read codes, ect. They are in the $130 range.
WisconsinDiesel is offline
post #7 of 22 Old 10-31-2010, 09:37 AM
JSchuricht's Avatar
It's the blue wire. You should be able to use the ground on the sensor, but I have mine grounded in the cab.
post #8 of 22 Old 10-31-2010, 01:44 PM Thread Starter
Let's go B's!!!!
Southpaw's Avatar
Thanks
I think I may move the ground wire to an actual ground also. Hopefully that'll fix it.
Chris
Southpaw is offline
post #9 of 22 Old 10-31-2010, 01:55 PM
chillls's Avatar
[QUOTE=
cool thanks
i like to know what things stand for sometimes
Dave
chillls is offline
post #10 of 22 Old 10-31-2010, 02:02 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
so this gauge didnt come with a sensor itself to plug into the head on an empty port?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
