Change head gaskets while engine in the truck? - Ford Powerstroke Diesel Forum
Old 10-30-2010, 08:25 AM
I have been loosing about 1/4" coolant every 2 weeks out of my degas bottle. I've looked everywhere - I still have not found my coolant leak, I just ordered a UV dye that is compatible with CAT ELC coolant and plan to pick up a blacklight bulb from from Home Depot.
If I still can't see anything - next up is a block test/ pressure test.
Oil still looks water free.
Ok - so worst case scenario, I have a blown head gasket. (Cracked block or head would be worse, I know) I doubt I have blown a gasket, but I want to be ready for it if I have to end up doing them. Can I change the gaskets in the truck? Has anyone out there done it that can offer some advice? I would use studs going back together and do the valve springs while it was apart, but I would really not want to have to go down this road. How heavy are the heads?
That's what makes it look hard!
Thanks -
Scott
Old 10-30-2010, 09:13 AM
Does it settle to one level then stop? or will it drain your degas tank? I fill mine up and it will drop about 1" below the fill and stay there, been like that it's whole life .
Old 10-30-2010, 09:35 AM
I am not refilling it this time around, I will see how far it goes. Its just strange, the cold reading never used to move at all.
Strange.
Old 10-30-2010, 11:13 AM
Keep posting on this.
Old 10-31-2010, 12:32 PM
Nobody has done head gaskets in the truck?
Old 10-31-2010, 02:07 PM
ive never done them on my SD, but have done them on lots of gas rigs. camper special with 390 is bout as close as ive come. i would try that before yankn the whole block. possibly injector cups?
Old 01-06-2011, 06:12 PM
I just got done doing heads in the truck. To put the heads back on you pretty much need a cherry picker. They are stupid heavy but it is doable for sure.
Old 01-06-2011, 07:19 PM
i have to fill my degas bottle every once in a while never thought any thing of it, its been like this as far as i can remember
Old 01-06-2011, 08:32 PM
not normal.. i have a small crack in mine and it never goes down for months..
