Cant find my diesel leak - Ford Powerstroke Diesel Forum
Old 10-29-2010, 01:27 PM
So I have had this leak for a while and I finally got around to putting new Orings in the separator valve which seems to be what is usually the problem. I still have the leak. I cant for the life of me find where it is coming from, I just see a drop hit the puddle in the valley every so often. I am looking for a write up on everything in the fuel bowl that can leak so I can check things one by one and go thru it and make it right. Any thoughts are very welcome too. Thanks
Old 10-30-2010, 07:24 AM
read another possible location, and thats the fuel "hard" line, running from left side fuel bowl, to back passenger side head. That rail, where it goes under the plenum, i guess it rubs on something, and overtime, develops a hole.
Old 10-30-2010, 08:16 AM
I had my drain valve go bad. New one from ford cost $60 (rip off) easy to repalce though
Old 10-30-2010, 09:38 AM
if you have an after market fuel filter (not a ford filter) it can leak out of the o-ring. but sounds like it is a slower leak. i would check all fuel lines and anything fuel related. i know you can put dye in the oil to find the leak, maybe do that with your fuel and use a black light to find it?
Old 10-31-2010, 08:54 AM
Its dripping worse now. I think I will take the valve off again and make sure its seated right. I do have an aftermarket filter, I will try a new one. When I look it looks like the diesel is dripping from the electric plug, does that come off and have o rings like the separator valve? Also the diesel is dripping from the weep hole on the bottom of the motor, looks like its coming out, is that a possibility?
