Finallyyyyyy...gauges!!
I know about time!!! I cant wait to get these freakinn things on.
Now for those that did their own install a few questions... I'll take any tips you guys have to give. I ordered the autometer z series from puredieselpower.com they had the best price on the kit with the color matched pod. I wasnt going cheap with this. $360 bucks but worth every penny I think. Im assuming i'll get instructions with the kit. I didnt order a t for the boost but I figured we could drill and tap something, what size do I need? The pyro is pretty straight forward drivers side manifold, drill, vacuum it out, install it and you're good! I did order the wiring kit with the gauges that PDP offered. Any tips besides taking my time and wiring everything up right? |
Sounds like you got it figured out pretty good. Just take your time, it'll go smooth.
You'll need a tapped 1/8" NPT hole for the boost fitting Here's a install write up, something to read while you wait Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke |
thanks.. ya those diesel manor instruction are definitely helpful.
shound have talked to ken, less then 300$ for 3 gauge pod colored match, with all the stuff to install them
ya but i dont like isspros..
Hey man I cant think of the site atm but there is a fitting you can put in you AIH and it has the boost fitting in it. Just a thought for ya buddy
Riffraff has those adapters.
If you have the tap, the AIH to boost fitting isn't hard to make. The local parts store had a drain plug that was the right metric threads, I drilled and tapped it to the 1/8 NPT, and was set. No more AIH, and perfect place for boost gauge... Don't forget to tape up the AIH wires, or remove them.
My AIH wires are taped up and i got a random plug in there that fits perfect haha. Meanwhile my bud has a t fitting laying around he said(ridiculous huge shop on a dairy) so we can do that on my map line. the AIH was a possibility too. i'll see what he thinks..
BTW. Props to puredieselpower.com for shipping my stuff that quick. They must have had a pod already painted my color ready to go, shipped it today and I ordered last night. Im impressed. Last edited by Dietoremain; 10-29-2010 at 09:44 PM. |
use a thick grease on that drill bits for the manifold, it helps hold onto the metal shavings. i drilled a small hole and kept re-greasing bit. metal shavings would destroy the turbo pretty quick. i also used a small telescoping magnet in the final hole to help get any shavings out. i do know someone said to drill it with the truck running, i think would make me kinda nervous but they said it worked. good luck man
