Missfire? How can u tell?
How can you tell if a cylinder is not firing? My truck has been idleing kinda rough and sont seem to have the power it use to? is it possible that a cylinder or mutilple cylinders are not firing? Will it throw it code or something?
Just dont seem like its got the power it use to. Im making 27lbs of boost still. Only other thing its been doing is taking a few more cranks to get it started. |
I would have a scanner put on it-a cylinder contribution test can't hurt as well
One other quick question? It seems like when I take off from a light at when driving normal (light foot) I dont ever see more than 5 psi boost. I have to really get on it to get to 10psi (still not floored, just heavy footing it). There is a long steep hill by my house I can mash the pedal on and get up to 27psi..
And when I'm running down the highway at 65mph it seems like Im making 3or4 psi. ( all of this is unloaded). My up pipes are not leaking I checked. Maybe Im just being crazy but I'd like to know if this all sounds normal? |
What kinda scanner? OBS2? and I guess Im going to have to look up a cylinder contribution test and see how or who can do that for me if I cant do it my self.
It sounds close-maybe a little low at 65,but I haven't checked mine unloaded at that speed-always been loaded since gauge install.
![]() 27 sounds kinda high,what year 7.3? ![]() Our trucks won't read OB2-you need to take it to a Ford dealer,a qualified diesel shop (if on is near you) or purchase the AE software-a regular scanner won't work. Last edited by icysmooth; 10-23-2010 at 06:25 PM. |
its a 2003 and I have Dp tuner on 80hp eco, I have deleted my ebpv, put a 4" turbo back on and have a turbo-master wastegate controler. I said 27 but its prob only 25psi and it only does it for a second unitl it shift. I havent had a chance to pull anything scence I have done everything. It just seems a bit sluggish, maybe its just me. Some days it seems to run like a 1000hp drag car and somedays it runs like a prius.. lol
Im going to find a good dealer ship and take it there. Im also going to order one of the new black cps sensors and change it first. The other day i went to get out to get something out of the bed and it died. I thought I bumped the key or something, but after reading some other post it sounds like my cps is acting up and it does take a few seconds to start up. Thanks for your help. |
