7.3l engine pull
Hello,
I was trying to salvage my oil pan in my 2000 f250 and after sanding it down it has begun to seep oil through a deep pit in the oil pan. My question is what shall I have done while the engine is pulled? New glow plugs? water pump? What would be cost effective while the engine is pulled? Thanks. Can anyone recommend a shop in NE Ohio? |
I'd do the up-pipes while you had it out. Depending on mileage, glow plus and water pump too if you want, but they're not bad with the motor in the truck.
Replace low pressure oil pump it is easier with it out. Rear main seal is always worth while you never know
