questions about remote start and block heater - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-21-2010, 07:28 AM Thread Starter
i am getting a good deal on a remote start and i was wandering if you can start the car while is still plugged in
it gets pretty cold in the winter here and it would be nice to be just able to start it and after 15 min just go outside unplug and leave
on my old gmc i had an aftermarket heater and it said to not have it plugged in while it was running
is this different?
will i damage something if i start the truck and it is still plug in?
thanks
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #2 of 13 Old 10-21-2010, 10:17 AM
Zaairman's Avatar
Quoted: 12 Post(s)
I've started mine before with it plugged in.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 13 Old 10-21-2010, 11:30 AM
I usually start the truck with the block heater still plugged in. I go out to the truck from the house with an armload of gear, coffee cup, etc. and want to place all of this jive in the truck before fiddling with unplugging the cord so while I'm in the cab I start the engine and then go outside and unplug. No wasted time, the engine is idling while I unplug for max warm up time before starting out.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #4 of 13 Old 10-21-2010, 02:46 PM
chrispaine's Avatar
I would say just don't let it warm up too much, could over heat the heater ha.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #5 of 13 Old 10-21-2010, 02:51 PM Thread Starter
i was thinking no more then 10 minute running in the morning
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
post #6 of 13 Old 10-21-2010, 03:18 PM
kd7skx's Avatar
Well just dont do what I did a couple winters ago. Dont drive off with it still plugged in. Kind of messes up the cord. Forgot since it was already running. One of those days I should have just stayed in bed.
My old truck, some times I wish I would have kept it.
2000 F250 7.3L
60,000 miles
4 inch Exhaust
TW 6 Bank Chip
Tymar DIY intake
Bully Dog pillar gauges
Guzzle's TC Lockup
Alpine sound system
XM
On a side note, take a look at my adventures through straight razor shaving:
kd7skx is offline
post #7 of 13 Old 10-21-2010, 03:29 PM
Beast Of Burden's Avatar
Dont feel bad, you arent the only one. I used to be a Cummins owner and I read alot of post from guys that drove off without unpluging their trucks, Im sure I'll do it one day too,lol
2000 F-250 Reg. Cab Long Box, 4x4, Auto., 285/75/16 GY Dura Tracs,
1990 Mustang 5.0 LX hatchback, auto, Prowler orange. Car has full exhaust, E-cam, Trick Flow upper and lower intake, ADJ. fuel pressure reg, A/C delete, AOD with hardened shafts shift kit and TCI 3500 stall, not yet installed 3:73 gears, and TFS Twisted Wedge heads
Beast Of Burden is offline
post #8 of 13 Old 10-21-2010, 05:23 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I always loop the cord through my mirror so I don't forget.
Zach
SLAPS Member #153
Zaairman is offline
post #9 of 13 Old 10-21-2010, 06:10 PM
Lifetime Premium Member
jbeasts10's Avatar
I plug my heater up when it gets down in the 20's and use my remote start.Never had any issues.All the heater does ,is keep the block/coolant warm,you wont have any problems.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #10 of 13 Old 10-22-2010, 06:38 AM Thread Starter
Thanks guys
And yes I drove with the cable plugged in before
The good thing is I have to back up from the garage and it just unplugs the cable from the extension cord. Lol
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
