Edge CTS guys help me out!
After pricing out the gauges and pod i want(boost/EGT/trans temp/fuel psi) its gonna cost me almost as much as getting the CTS with EGT probe, i just want some opinions on how you like it and whether you would do it over again? Also will the CTS monitor fuel psi and HPOP?
....bump....
Theres no question. I would buy it again if I had another truck to use it in
Anyone know about the fuel and hpop pids
They are not out yet, but that is why to get the expandable pyro so when they do come out with them, just plug it in. And yes I would definately buy the CTS again!
Expandable as in I would still need to add a sensor under the hood? I would have thought that the PCM already moniters thos things.
No the PCM doesnt monitor fuel pressure
i love it!!!!! it dose not monitor hpop but i think it dose fuel pressure i have like 20 somthing gauges. it is so much better than gauges it think and it dose diagnostics also. it is simple to use once you get the new program for it....i think mine is only a beta program.
I think ill be ordering the CTS soon with EGT probe and hope they release some new pids or just get a couple of standard gauges if needed, how do y'all have it mounted?
As majek pointed out, be sure to get the expandable pyro if you want to add the hpop and fuel stuff.
