01 E350 7.3 cranks great but no start...IPR? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-19-2010, 04:31 PM Thread Starter
Ok, this is an 01 E350 7.3 Ambulance, truck has been alittle slow to start when cold and runs rough till warmed up but now it just cranks but wont start, it acts like its going to start but just not getting enough fuel, i dont have access to a scanner and the CEL isnt on, frame mounted lift pump is running. I was thinking maybe its a CPS but im leaning more towards a bad IPR or bad IPR orings and looking for some advice.
Thanks
HotRodV6 is offline
post #2 of 14 Old 10-19-2010, 06:33 PM
Beast Of Burden's Avatar
I know this is the answer nobody wants to hear but start by checking your battery cables. I had the same problem, I changed the IPR, and the cam sensor and still had the same problem. So I called my budy who was a Ford diesel tech for 20 years, the first thing he did was clean the battery cable ends and terminals on the battery and it fired right up. I felt so stupid for letting my truck sit for two weeks and throwing a bunch of money at it just to have it turn out to be corroded battery connections. I would start there, if it doesnt work it still didnt cost anything and it never hurts to have clean connections
2000 F-250 Reg. Cab Long Box, 4x4, Auto., 285/75/16 GY Dura Tracs,
1990 Mustang 5.0 LX hatchback, auto, Prowler orange. Car has full exhaust, E-cam, Trick Flow upper and lower intake, ADJ. fuel pressure reg, A/C delete, AOD with hardened shafts shift kit and TCI 3500 stall, not yet installed 3:73 gears, and TFS Twisted Wedge heads
Beast Of Burden is offline
post #3 of 14 Old 10-19-2010, 06:35 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
Thanks
change the cps,its only 30 bucks....
harley1rocker is offline
post #4 of 14 Old 10-19-2010, 06:37 PM
My buddy that fixed it for me said that the computer needs a certain voltage ( I forgot the exact voltage) to the computer to fire the injectors. If the voltage is too low, the batteries may still have enough power to crank the motor normally but not enough to fire the injectors too. If you hook up a battery charger to give it a boost does it start?
post #5 of 14 Old 10-20-2010, 10:32 AM
Nosparkplugs's Avatar
Could be your pcm fuse under the dash. Its number 22 i believe and it also runs the fuel bowl heater. If its blown unplug the heater and put a new fuse in. pretty common
Early 99 f-250 cab and half longbed 4" intake and exhaust edge evolution II(for egt and boost guage only), trans temp guage trucool max 40K, TW 6 pos
Nosparkplugs is offline
post #6 of 14 Old 03-29-2011, 10:56 PM
Did you ever figure this out?
Our 2000 E350 just started doing the same thing. Did you figure out what was causing this on your van? Thanks
mammasvan is offline
post #7 of 14 Old 03-30-2011, 08:47 AM
ridiculously_necessary's Avatar
check your batteries, you need voltage. do you have a spare cps sitting around? pump is running?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #8 of 14 Old 03-30-2011, 07:38 PM
I've got something close to the same problem. After I did an injector buzz test when the engine is cold I found out only 3 injectors work. When I get the truck started it runs fine when warm. If I do the buzz test when the engine is warm all the injectors work. I will be changing the injectors this fall... lol
RICHE is offline
post #9 of 14 Old 03-30-2011, 09:24 PM
running for now
Changed the fuel filter... still cranked over but no start.
Changed the CPS... still cranked over but no start.
Disconnected both batteries and checked them independently... aok, reconnected and still no start.
Opened up the HPOP and put a rod down to check oil level. It was full... Closed it up again and motor started right up.
So I have no idea what was wrong or what fixed it. The van was 2 quartz low on oil before it quit starting. Maybe it had something to do with the HPOP. I'll drive it around for a while and see if it does it again.
post #10 of 14 Old 08-14-2013, 12:01 PM
Thanks
I have a 97 e350 retired ambulance with a 7.3 powerstroke in it and mine is doing the exact same thing, turns over perfect sounds like it wants to fire but doesn't.. changed the cam sensor, fuel filter, oil and filter and now the ECM still wont fire, I need help and insight on what to look at now.. battery cables are clean and tight, someone told me to check the IPR sensor and everything I found online showed it under my turbo so I took it off and its not there! really frustarated and need advice please!
jasongritzner is offline
