front axle leaking - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-19-2010, 08:45 AM Thread Starter
front axle leaking
my front axle i belive is leaking on the passenger side. i noticed it when i was fixing a hole in my oil pan. i wiped it off and drove it around a little bit and when i got to my house i looked at it again but i couldnt tell if it was leaking again. Any ideas of what it could be
mxjunkie123 is offline
post #2 of 4 Old 10-20-2010, 06:09 PM
kevinj1's Avatar
The shaft seal inside the diff. You have to pull both axle shafts, remove the diff cover then the carrier bearings, They are installed from the inside out
Central, New York,
'02 F350 XLT CC,SB,Dually 4x4 7.3L auto 143K mi.
ZooDad, NAPA 6637, '08 Mirrors, DIY WVO system
Towing 2011 Flagstaff 8528BHSS
Truck & Trailer GCVW 18980 Lbs 6/20/2012
kevinj1 is offline
post #3 of 4 Old 10-27-2010, 06:29 PM Thread Starter
i also found out that the passenger side hub is wiggling a lot. i had a two friends think it was a wheel seal. but i dont know any way to find out besides pulling it out.
post #4 of 4 Old 10-27-2010, 07:14 PM
u need ball joints also then
wiyrs is offline
