what load resistor do i need?? - Ford Powerstroke Diesel Forum
Old 10-17-2010, 11:09 PM
okay im gonna upgrade to all LEDs and i see so many diffrent types of resistors, can someone link me which ones they are using and that they actually work lol ill need the turns and the tails.
Thanks
so which of these would work? the 50 watt is cheaper, but i dont want it to be too much or anything,
25watt
LED bulbs Load Resistor Turn Signal Fix 10ohm/25W 2pcs: eBay Motors (item 400156061145 end time Oct-19-10 19:15:05 PDT)
50watt
LED Bulbs Load Resistor Turn Signal Fix 6ohm 50W 2pcs .: eBay Motors (item 400160828171 end time Nov-03-10 13:15:10 PDT)
Old 10-18-2010, 10:23 AM
okay do i need a 6ohm 50 watt, or 10 ohm 25 watt?????
Old 10-18-2010, 11:08 AM
Air Assault!!
Send a message via AIM to MPTonyT
Low beam headlights use 25watt just fine. the 50 watt are more for high beams. For a blinker i would get the 25watt and they should be fine. you will need one per bulb.
Old 10-18-2010, 11:32 AM
Call me lazy, but I just put in an electronic flasher unit. (EP-27). It is not load dependent like the stock ones are so I get a nice steady flash rate.
Something to consider.
Old 10-18-2010, 02:39 PM
25watt
50watt
Old 10-18-2010, 04:50 PM
anyone know?
Old 10-18-2010, 05:00 PM
Air Assault!!
either will work. 25 probably better.
Old 10-18-2010, 05:03 PM
When you say better what do you mean? sorry i honestly dont understand what they actually do... i know they trick the truck into thininking its a real bulb, but do they actually take taht power like will the truck shoot 25watts to the resistor?
the 50s are cheaper but if they might make it still flash or something then ill get the 25s just kinnda wondering what it is.
Thanks
Old 10-20-2010, 02:24 PM
does anyone know for sure which ones i need for tails and the turns???? id like to hear from someone who is using them themselves on one of our trucks??
