puffing Black SMOKE on acceleration...diagnosis process wanted - Ford Powerstroke Diesel Forum
Old 10-11-2010, 05:00 AM
The 2000 Ex with 150K miles an 7.3L had been sitting with almost no fuel for four months before I bought it. On the drive home my bride was following and said that any time I accelerated away from a stop sign, she'd see smoke coming out of the exhaust...she said it was more black than white or blue.
What do you guys see as the list of tests to run? Could it be as simple as old fuel?
Old 10-11-2010, 05:04 AM
Does it have a programmer on it? Bigger injectors?
Old 10-11-2010, 05:36 AM
Thats what it sounds like to me. Possible dirty airfilter?
Old 10-11-2010, 05:50 AM
change all the filters first. plugged air filter will cause smoke. then look to see if it has a chip plugged into the PCM.
Old 10-11-2010, 07:10 AM
also check your turbo boots for cracks and such. as well as up-pipe gaskets.
Old 10-11-2010, 07:19 AM
Old 10-11-2010, 07:31 AM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
ya sounds like a good thing to me, a little black means the diesel is running good hah..
Obviously to much black is straight up annoying, but a little is great!
Old 10-11-2010, 11:19 AM
mine on stock settings blows a little black on accel... usually boost leaks are a cause of this on higher mileage..
like they said check the turbo boots and up pipes..if theres black soot around the up pipes your loosing boost, and check the boots and make sure the clamps are all tight..
check the pcm under drivers side dash and see if theres a programmer in the end of it..
is it slow? or does she get up and go?
