Parking brake question. Cable under leaf??
Read a couple threads about bad design for Parking brake, which I need. Brake doesn't hold and light doesn't go on. The pedal does pull the cable and compress the spring so I was going to try to tighten the star that people refer to. I can't find it though. Any instruction on what this is??
Also, my cable is routed under the leaf spring and it is makes the leaf spring touch it!! There is a black rubber sleeve that shows wear. Is this the stock config or did previous owner do this? Where should it be routed?? |
The adjusting stars are under little oval rubber plugs in the backing plate under the axle tube. Also my cable is under my spring, been that way it's whole life.
theres a single connector wire that plugs into the pedal assembly theres prob a reason why its not hook up. the reason for mine is that when i release the parking brake, the light never goes off, cause the rubber that hits the switch is missing
Well I found the oval plug and there is nothing behind it??
Also, to second responder, the pedal actually does move the cable. What connector am I l looking for?? |
Great thanks. So I need to check that connector and maybe replace. That hole is what I was looking at. So I will jack up both tires and spin the tire until i see the star. Rotate until tight, then back of 2 clicks. Thanks!
and the star is stationary. u jack the tires up to spin then and check the ebrake pads drag. |
