Cutting stock exhaust?
It seems the accepted standard is a 4" straight pipe all the way back. Would it not be the same amount of flow and back pressure by cutting back the stock system, for example cutting it half way so it dumps under the truck? i already straight piped the stock 3.5" exhaust but it runs all the way back to the stock point.
you still are pushing through a 3.5 half the way, and then you have to deal with soot under and up the side of your truck.
im pretty sure stock is 3" but turbo diesels. dont require "backpresure"
i cut my stock exhaust right infront of the muffler. not to bad of an issue with soot unless i turn my programmer on. sounds ok. really loud in the cab. i am still going to put on a 4" exhaust though.
stock is 3.5" on my truck.
IMO let it be. 3.5 is plenty unless you're pushing a ton of power(aka over 500hp) and dont dump it under the truck its noisy as crap. had mine that way wasnt fun.
i had mine sawed off before the muffler before i had the stacks and the bottom of the truck was black and it stained the license plate. also made the truck smell like cancer
If you're not looking at heavy load hauling-you have an early 99-right?
Just get rid of caty converter-pipe it through- |
stock exhaust is good for around 400HP all day long, alls your going to see with 4 and 5 is a slight drop in egts but the noise is going to increase alot, the 5" is extremely deep, i love it
