95 engine in a 01
Our service truck at work is an 01 f350 7.3 auto. The engine is shot. I have an engine out of a 95 w/ late 99 injectors, dptuner computer reflash, manual tranny. What will it take to to make this fit in the 01?
Are the turbo intake spyder and the like from the 01 engine still good?
Yes. the 01 sounds horrible, blue/white smoke, runs/dies/runs/dies. They limped it in at 15 mph last night.
Yup swap the turbo and intake parts over to the 95 engine and go for it
what about the pcm, lift pump, hpop?
move the injectors from the 99 to the 95 motor and keep the pcm
lift pump/fuel pump will work better from the 99 actually. youll need a 7/8" freeze plug to plug the fuel pump hole in the 95 motor. dont let the pump tappet fall in the motor. keep the 95 hpop as it probably has the anti-drainabck stuff. you might be able to send the 01 hpop to teminator engineering to have it modified to git the 95 motor properly. move the fuel bowl from the 99 to the 95. change the glows to Motorcraft ZD11's ONLY since your already in there. there will be otehr differences, like the fuel line routing etc that youll be able to see and figure out. but thats the bulk of it.
the 95 motor already has late 99 injs installed. Jody reflashed the pcm w/ a 60ish tow burn.
The engine is on a stand in my garage at home. I have a chance to sell it to the shop at work, as one of their service trucks(01 f350) has crapped out. I'm trying to find out, for the service mgr, what is all necessary to complete the swap. Also I need to find out what is fair price. |
